1 - 19 of 19 Posts
I'm selling a used set of TS-A6971R 6 x 9 3-way speakers which were removed from a G2 Legend.
I haven't had a chance to test these yet. They were just recently removed from a parts car that didn't start so I can't guarantee that they work or how well they work yet.
Upon request I can have them tested, but it may take me a week or more to get down to a friend's audio shop and have them plugged in.
No visible damage of any kind, speakers are in good shape. Items sold AS-IS.
NAME: PIONEER 6 X 9'' 3-WAY WITH 300 WATTS MAX
MODEL: TS-A6971R
FEATURES:
* Woofer Cone Material Composite IMPP Cone with Interlaced Aramid Fiber
* Surround Cloth
* Voice Coil Bobbin Glass-Imide
* Damper Conex
* Mid-Range 2-1/4" Laminated Polyester Fiber Balanced Dome (pours out sweet highs)
* Tweeter 3/4" Film Cone
* Basket Design Shallow Basket for Wider Installation Coverage
* Speaker Grille New REV Spoke Grille
SPECIFICATIONS:
  • FREQUENCY RESPONSE: 28Hz TO 33kHz
  • IMPEDANCE: 4 Ohm
  • MOUTING DEPTH: 2-7/8'' (73mm)
  • MOUTING DIAMETER: 6'' X 8-7/8'' (153 X 225mm)
  • PEAK POWER (MAXIMUM): 300 WATTS
  • RMS (CONTINOUS) POWER: 40 WATTS
  • SENSITIVITY: (1W/1m) 93dB
MARKETING INFO:
How can you get better sound for your car, without spending alot? Step up to the new TS-A6971R 6" x 9" 3-ways. They feature upgraded power handling of 300 watts max. (40 watts nominal) to pump out big sound, and an incredible new Laminated Polyester Fiber Midrange that pour out sweet highs. And we're continuing to lead the industry with next-generation technology for improved sound: the cones, magnets, surrounds, the voice coil wire, the basket and more are all high-performance components that make up a great speaker.
Composite IMPP Cone with Interlaced Dual Aramid Fiber
One of our major speaker breakthroughs was IMPP (Injection-Molded Polypropylene), which allowed cones to be lighter AND more rigid. Then we added long stands of Aramid fibers into the mix, for extra strength. Now, we've gone even further with the TS-A6971R, adding a second type of Aramid fiber that makes the cone even stronger and tougher, without adding weight. So what does this mean to you? Tighter, more powerful bass. A rich, natural sound character with excellent midrange depth. And the durability to stand up to the high volume levels, humidity, and temperature extremes that thrash other speakers.
New Balanced-Dome Midrange with Laminated Polyester Fiber
Better technology, better performance: instead of conventional materials, we used a laminated polyester fiber in our new balanced-dome midrange, the same material used in the high-end REV-series speakers. The key to this material is that it is 30% lighter than conventional materials. That difference in weight means faster and more accurate response, for exceptionally clean, detailed music.
Heat Resistant Polyester-Imide Resin Voice Coil Wire
Creating mechanical energy is hot work, especially at high volume levels. And as we all know, heat can cause distortion. That's why the TS-A6971R uses a heat-resistant polyester-imide resin voice coil wire. It allows the voice coil to handle more heat, improving input power handling as well as reliability. So go ahead. Turn it up.
Asking 45 + shipping.​
1 - 19 of 19 Posts
