1 - 20 of 24 Posts
What kind do you use?
How often?
Anyone realize any gains/losses from use/non-use?
Good or bad for our engines........manual/auto?
Ghost
meber
You can also buy it at the Acura dealership. It will cost about $20.00 a can.
Whut... I didn't know that. I coulda got some MacDonalds on the way to the dealer (had I went to acura instead of tisher). I spent like 26.75.
KNLNGUS!
my dealer will not carry any additives. I was told that Acura does not recoment any additives, so they don't sell any. I was also told that if you use any it could void your warranty! Not a problem for most of us. I use 104 octane booster every time I am going to burn a tank of gas on the interstate. You have to use a whole tank at one time for it to work. I have used this on a variety of cars. I always noticed a decent increase in MPG, pick-up, and the car just felt better.
Later!
Lee
Thanks fellas,
So it seems the concensus is BG44K with every oil change? I change my oil at 3000K vs the recommended 7500K in the manual. So should I use the additive with every other oil change then? I just don't want to use it too often and ruin something.
Ghost
infinite said:
44K is supposed to work pretty good. I have the H/A specialist put in a can with every oil change.
Caution: you may clog your catalytic converter with deposits by using any fuel system cleaner too often. I found these guidelines for BG 44K from another forum:
As to fuel system cleaners - BG44K is the heavy duty stuff - and recommended in Volvo and BMW TSB for removing carbon deposits, particularly from intake valves and fuel injectors. Use no more often than 2/yr, and only 1/yr if your system is in reasonable condition. Pour the can in the gas tank only with the tank full. Use it when you will be able to drive out a tank of gas in a day or two. Plan on changing the oil and filter soon after use as it can contaminate the oil with unwanted chemicals. Distributor at website: http://www.bgprod.com . You can also use a special tool with reservoir and spray attachment hooked to shop air for injector cleaning. 3 BG chemicals are used, 2 in the sprayer and one in the tank. Engine is run with chemicals spraying. Takes about 15 minutes. Results were immediate. Idle before treatment was 650 rpm now 850-900. Low speed throttle response is very smooth. These products only available to professional shops. Find one in your area and try it out- I highly recommend this product. BG 44K is very effective.
You can get it for $18.50 at any Mercedes dealership. BG44k is the only fuel additive on the market that REALLY works IMO
MD
Acura dealers used to carry it... Try Saturn too
Try Saturn dealers. One of my friends in Miami got his stuff from a Saturn dealer
BTW price varies. Ive heard 19 bucks
Got mine for 25 bucks tho (including tax)
I mustve been incorrect in saying all Mercedes dealerships carried BG44K. When i was on vacation i stopped in Lynchburg, VA, at the dealer there. They told me all dealerships should have it so i assumed they did. Oh well. If you wanna save a few bucks and youre in that area you should stop there..... 25 bucks is a bit pricey, after all. But you gotta do what you gotta do, that stuff is the ****.....
MD
Discussion Starter · #18 ·
OK,
Bought the BG44K from Philips Olds/Mercedes Dealer in Norfolk, VA for $14.95. I talked to the service mechanic, and he said that this stuff was the shiznit! He then told me to make sure that I use it in a full tank of gas and change the oil after I burn all of the fuel up. Thanks fellas!
Ghost
i know its a good idea to put the stufff in on a full tank and try to use the tank up fairly quickly like 3,4 days right? would it be good to use right before a road trip on the highway or with city driving ?? i was thinking it might go through the fuel system to fast if it was used on highway driving? maybe it would be better? what do u guys think
Discussion Starter · #20 ·
That is a good question........and I didn't ask the mechanic. I am going to D.C. for the 4th and I will use a full tank going to and fro within the couple of days that I will be there. I think that should do it. Then I will change the oil on Saturday when I get back.
Ghost
1 - 20 of 24 Posts
