Here's the address at the bottom of my signiture with the pics I took yesterday,11-4. I am still trying to fing a body person to do the work, but mechanicly, it's all there!!
Ahh I see, I am in the process of dropping and LS/vtec into a 1986 honda accord hatchback. It looks completely stock on the outside, but I have full suspention including tokico illuminas from a 1990 civic, poly bushing all around, Lowered 2.25" and drilled and slotted rotors + I converted the rear drums to disks. Good luck with the build, I will be watching the process.john bigonion said:My daughter has a 89LS 4dr, it had a slite accident. She started whining about the grill so I gave my grill. Besides, I like the ugly sleeper look.
Thats kinda an Oxy-moron. If you have a big turbo then it will boost alot, but spools slow. If you have a small turbo then it will boost low and spool quick. If you are doing twin turbos then you will only need two small quick spooling turbos. That should put out plenty of boost.Badjack10 said:have you piced what turbos you are going to be using? i am having trouble with finding one. that spools fast but still puts out a good amount of boost.
paint the muffler flat black, i think that would be more sleeperish and look better.Legend_master said:Ahh I see, I am in the process of dropping and LS/vtec into a 1986 honda accord hatchback. It looks completely stock on the outside, but I have full suspention including tokico illuminas from a 1990 civic, poly bushing all around, Lowered 2.25" and drilled and slotted rotors + I converted the rear drums to disks. Good luck with the build, I will be watching the process.
Well I thought about that, it's a 2001 V6 eclipse muffler and you can't even tell that it is not factory. I am running the factory LS internals that have ben balanced and friction coated. I am running a 2 layer thin headgasket to gain more compression. I am running a GSR head that has ben milled to yeild a little more commpression with ported intake manifold and I removed the butterflies from the IM. I should come out to be about 10.5:1 Comp when I am done, but a sleeper none the less.Ken said:paint the muffler flat black, i think that would be more sleeperish and look better.
What intake manifold u got in there? what about internals?
:werd: to talking to the experts. I bet that legend dosent handle so bad now, but factory to factory the accord handles about 10 times better then my Legend did. Since I did all the mods, the car really handles like a dream.john bigonion said:As for turbos, stop talking to us and talk to the experts that sell and tune them every day. And that hatch is pretty clean, I had a 88 accord coupe that handled like a gokart.
