1 - 20 of 21 Posts
will a g2 engine fit in a g1 legend coupe. WIth out much mods needed. OR should i do a whole rebuild to a g1 engine. Because i plan to keep my legen running more then 200k miles, I heard 200 is its max. And so i will need to do something with the engine. And is there anything else i should worry about?
Engine
Transmition
Bearings
please add more and help me with pricing.
I am currently at 121k
Thinking about going up to Montclair once a week, est 1k mile a week.
G2's will not fit into a G1.
They have engines that are lined up completely different.
One is left to right, the other one is top to bottom. So no go on that one.
200k is it's max? hardly. I've seen them go well over 250k. If you keep it maintained, it should last well over 200k.
Can you please give me a list of matinence things i should be doing to the car, and how much psi should i be putting in the tires, i am about to inflate them today, they look alittle flat, but i dont want to put too little or too much. Thanks again.
Yes, anything is possible with a little(or maybe a lot) of moola...
lilboi tony said:
nOo lota moola put into the car no good, wont bable to afford lap dances at strip clubs. =P
I thought you were that guy that was 14 years old on these forums and said you were leaving...? Maybe I'm mistaken...
Is there another engine that will fit in G1's with a few mods? Maybe the accord v6 engine?
· 0000$$$$0000####0000
Engine
Transmition
Bearings
200K is defiantely not the max. There are many G1s with well over 200K on the original engine, and smany over 300K. There are many G2 Legends with wellover 100K, some over 200K, and a few I've heard over 300K.
You could always try putting NSX heads in the Legend engine. It's the same engine series, so it shouldn't be too hard to make them fit. There's a guy on the forums in So. Cal that will hook you up with the electrical on the swap for free if you want to come up with the engine and parts. That would be interesting to see. The other engines that are the same series are the 94-97 Accord and I believe the new 3.5 liter engine in the Odyssey (sp.) minivan.
NSX engine would fit? or just the headers? Imagine getting 290HP out of your legend. Wow. I bet a NSX engine would be expensive. A minivan engine fits too? I can imagine the torque. Hmm... I bet with enough money I could get a Viper engine in too.
The NSX headers wouldn't fit. The heads probably would with a little modification. You would need a lot of modification to fit the whole engine in since it's mounted so much differently than the Legend's.
A Viper engine would be just about the hardest engine there is to put in a Legend. Nothing's impossible, but you'd need some serious cash to do that swap.
good God, can you imagine a Viper engine in a Legend???? man that would be an awesome sleeper, cept the exhaust note would prolly give you away, an another thing I think you would have to convert it to rear wheel drive, since it would probably just boil the front tires to oblivion :D
thats what counterfit ones is for...oh sh it...did i just say that out loud? oh well:D
1 - 20 of 21 Posts
