I post this in the hopes that I've over looked something. My gentex mirror stopped working a couple weeks ago and I finally got around to trying to fix it. I'll turn the car on and the mirror will come on and it will work normally for a good 60 seconds and then shut off. The mirror won't work again until I unplug the harness, let things reset, then plug it back in. Even then though, it only works for another 60 seconds.
I checked the power and grounds and they're setup correctly and all the fuses are good. The reason I tend to think its fried is because a sticker on the original box said, "connect the all-the-time-power to the ignition power along with the ignition power wire". Not explaining why, I decided to follow the instructions and set it up as the wires are labeled figuring it had volatile memory and would forget my settings if I did what the sticker on the box said.
So unless I've over looked something, I'm about to buy another off ebay. I simply can't go without a dimming mirror with a compass and temp sensor.
