1 - 8 of 8 Posts
Well, All depends on you. If you want a LO LO or the conservative look. Eibach would be more conservative.
This is a quote from Thai.95
I would say if you want a:
mild drop Ebiachs (1 inch)
or a serious drop HR's (1.5 inch)
Or a redicilous drop Ground Controls (1-5 inchs)
They also go that way in price:
Ebiach $215
HR $ 218-260
Ground Controls-$399
I have Koni's/Ground Controls and I think the ride is great, almost like stock. I have the shocks set on FULL soft, and I have no problems with the ride.
The great thing about GC's is that you can control how high you want the car and make it look exactly how you like it. With the other two brands (HR / Eibach) you get whatever drop it is, and you're stuck. Plus I've heard that sometimes the car isn't exactly level after you put a set of those springs on. GC's - you have the option to make it whatever you like!
Five- O
I have the eibachs on my g1 and the rears sit lower then the fronts- From what I have read this is normal w/ the eibachs.
If I were u I would save a little more and get the GC
Good Luck
Esti
If I choose the GC setup, do I have a choice of coil manufacturers or is Eibach the only one available. BTW, what spring rates front & back are those coilovers that you're using?
502MotorSports.com
GC uses Eibach springs, however, you ca nspecify spring rates before you order them
1 - 8 of 8 Posts
