Hello everyone I am a little bit concerned about how hot my Legend is running. I believe that it is running hotter than it should.
So here is what is heppening:
The temperature gauge on my Legend has never gone above half way ever. Not when it is going in traffic with the A/C on or in the hot weather. I have never seen it go above that mark at all. I even had a radiator which was leaking about 1 litre of water every couple of weeks and the gauge still never moved. My Nanna had the car before me with the leaky radiator and she used to drive it around with no water because it would all leak out (I used to top it up whenever I saw the car though) and the Temperature gauge never moved then either. So I am wondering if there is somthing faulty because it is lacking power and seems to be getting really hot.
I had a look under the car today while it was hot and there was smoke or steam coming from somewhere around the CAT. It looked like white smoke coming from somewhere around there. I could not keep my head under there for too long because the cooling fans were on and it was hot enough to melt your skin.
Also when I stop the car I let the car idle with the fans on until they stop. It usuall takes about a minute or two but lately they have not turned off at all because it has been so hot. They run on high speed until I turn the ignition off. Otherwise it takes about 15-20 minutes for the fans to turn off.
One more thing, the weather here at the moment is over 102 during the day. Now if you combine that with A/C and some tough driving the gauge should move a little but it never does.
Now I have done the thermostat and there is coolant in the radiator and the radiator has been replaced, I don't know if it was a second hand one though.
So the only two things I have in mind at the moment is to take the thermostat out because I can not keep running it so hot in this hot weather (The fast idle lasted for about 30 seconds when I first started it up this morning then it went back down to normal idle because that is how hot it is) and if anybody knows where there is a link or a DIY on the TB coolant bypass I would also like to do that too.
