1 - 9 of 9 Posts
· Domesticated *******
Yeah it's overpriced, but it's worth the features it provides. The ribbon cable inside is about 6 feet long and can not be spliced or replaired. Once you take apart the clock spring good luck getting it back together. When I got my new one I tried to take apart my old one to fix it and make a spare, but it was very fragile and alot of the plastic would not hold together. I don't see how it could be rebuilt to be made safe and reliable.
kotetu said:
cool, thanks for the info. Did you find out what broke in the first place? Also, what else uses the clock spring? I noticed only my radio buttons don't work.
I've never seen one, but it should also control the cruise buttons. If you would like to send me your old one I can take a look at it, I'm extremely good at fixing things so if it can be fixed I'm sure I could do it...
Thats the way it starts. My horn quit 2 months before the rest went. I had to make a u turn one day and I heard a snap and followed by the ABS light comming on.
Air Bag, Horn Cruise, Radio controls are connectd by the clock spring. The thing is glued together and the part that breaks is a thin plastic ribbon cable thats about 6 feet long.
Logic, If you can fix it I'll pay you to fix mine. I'm good at tedious work like that. I couldn't do it. You retty much have to break it to open it. Let me know how the repair attempt goes... :)
· FIXER
There is a ribbion type electrical harness inside it. Like the kind used inside a computer to connect small components. It really can't be repaired.
1 - 9 of 9 Posts
