1 - 2 of 2 Posts
Does anyone know if there is a way to aim our headlights?? My left headlight got hit and my beam pattern is kinda messed up. Anyone know what i could do??
GS Hog
Yes, there are two points of adjustment; one for horizontal, and one for vertical.
They are both located behind the headlight housings.
The vertical adjuster is located between the high and low beam bulb covers, and the horizontal adjuster is located on the opposite side of the low beam bulb cover (closer to the fender).
They look like gear teeth, and you use a philips head screwdriver to make the adjustments.
1 - 2 of 2 Posts
