My headlights never stay in the same CENTER aiming.
The problem is with the vertical and horzontal aiming.
The little bubble is always too up or too down even after i put it in the middle.
Do you guys know what the problem is? THanks...
· 502MotorSports.com
1- mods? (suspension, + wheel/tire, etc)
2- are you aware if your struts/tires/springs are worn?
3- has the car ever been in an accident?
Think of it as a level used in carpentry/construction...it is very sensitive, so you will need to move slowly for the fine adjustment, and for the coarse adjustment...well, start off with the fine adjustment first, and see if this works for you. The car must be on a level surface for this to be accurate.
holla back
the car's been in an accident. sometimes the headlights will stay in place..but then sometimes it goes extremely low and extremely high...
i think everything is still pretty good that you mentioned Leon.. and there is no mods on it...all stock...
what can i do to solve this annoying problem...thanks man!
