About 2 months ago my driver side headlight harness melted(result of high wattage aftermarket HID bulb) and I paniked
I then asked why this happened in the other forum(This forum was not available yet
) I then learned why the bulb harness fryed (result: High wattage Bulb). I was told by some to get a bulb harness upgrade for est cost $40.00 and others just simply replaced the bulb harness from another from AutoZone or a junkyard. I being ignorant and stubborn took the cheap way out buying a harness from Autozone for a few dollars. I spliced it in and replaced the fryed harness. Everything then worked fine untill last night...
. The same side headlight harness burned up again!!!!...!!!
!!!!!!!!!. This morning I woke up and went to the local junkyard and the harness from a Honda and spliced it in. Everyhting works fine now but I know it will happen again!!!!!!
!!!!! !!!!.The problem is I don't have a job and have now money!!!!!!
!!!!Now the question is
:Is there a stronger 9006 bulb harness on a different car that can withstand the immense wattage???
This way I can pull it from the junkyard and have now problems...Thanks...
