0000$$$$0000####0000
Roger said:
MY NEW FRONT HEADLIGHT CLOUDED UP WITH CONDENSATIONS , DOES ANYONE KNOW IF THE FRONT PLASTIC COVER WITH THE CLIPS COMED OFF THE HEADLIGHT???
ALSO ANY SUGGESTIONS FOR KEEPING THE FOG OUT?
The headlights are sealed with some form of rubbery sealant. IF you remove the clips, the lights will still not separate. If you heat up the adheasive sealant, then the lens can be separated. It is very unusual for the OEM headlights to have condensation. I would check the entire headlight for any cracks in the plastic casing. If you fine none, they adding some additional sealant in the seams probably would cure the problem, unless the condensation is coming through from the headlight caps.
I'm too sexy for my car
please keep cap locks off and what is "comed off" :D :D
j/k
I had the same problem but after awhile it just went away. I will be taking a look at them pretty soon to try to seal it off more so it wont ever happen again.
