hey how can i fix my head light harnness? today i wouldn't turn on and when i looked at it it was burned . i dont know if the bulbs still works. how can i replace this and how much does it cost to fix this. also one of my friends broke my door handle and i cant fix it from the inside taking my door panel off can anyone help me out here these things have happend in the last week.
It seems to me from my experience that the leading cause of a headlight harness melting down or burning up as you call it is from the use of high wattage aftermarket bulbs... The easiest fix for this is to go to a junkyard and cut a few headlight harnesses off of an old junk car and re-splice the wiring... shouldnt cost you much and im willing to bet that your bulbs are ok...
vito
I would not recommend splicing a headlamp harness. Better to find used ones and replace them as a unit. The splice tends to corrode over time. Then, if you intend to use high-wattage bulbs, buy an aftermarket high-wattage lamp harness/relays. Well worth the $50 or less. I have used high-wattage systems (with harnesses/relays) for many years. Never had a problem. Currently have an 80 watt application in the Legend.
I am unclear about the handle problem. If you can't open the door from the inside, the mounting tab has broken and you need a new inner handle assy. If you can't open it from the outside, the handle has broken (they are sold prepainted). You should be able to open the door using one of the two usual methods. If the vehicle is a Coupe, you must be especially careful in supporting the inner door panel so that it does not break the inner door handle mounting tab to which the lock assy cable is affixed.
