ok i got fine sandpaper and 1500 gritt sandpaper and the 3m rubbing compund and did everything and my healight look like crap. Does the plastic polish help this or what the hell did i do wrong? The 3M rubbing compound say it fills holes and stuff with 1500 gritt paper so i got that. And it doesnt do a damn thing someone please ehlp me.
If you can feel the depth of any pit or scratch with your fingernail, you are in for a lot of sanding. I suspect that you just have not applied enough time using the 3M polish. The 1500 grit will result in the surface becoming opaque and it will take quite a bit of elbow grease using the compound to polish the lens.
yep man your right i went out and put some time into it and it came out good. I still need the plastic polishthough i think.
