1 - 7 of 7 Posts
hi, what exactly is the heat shield? whenever my car is idle or just moving real slow, you can hear some sort of like rattling, clanking noise coming from under the car somewhere. but when im idle and just press down on the clutch the noise goes away, and when you release the clutch it comes back. anyone have any idea if its the heat shield, or something else? thanks
Blk/BlkGS6
yea i also have a slight vibration sounds sometimes at starting da car and at low speed acceleration.....................is it da heat shield??????? its annoying sound..............wats its purpose neway? if u wanna lower ur car 1.5 inch with h & rs, and .75 inch konis......so 2.25 inch..............can u go over bumps and steep driveways (btw wud dat be too low for steep driveways?) safely............if u remove dat shield.........??
502MotorSports.com
yes, thats it!
and, BTW you will be fine on the drop...just make sure offset is right
1 - 7 of 7 Posts
