sounds like the alternator went dead after you turned it off
If the battery if showing full and it doesn't turn over then you still have a battery problem. The alternator will not keep it from starting if the battery is good.i did however recharge it that night with the recharger and the battery is full now...and still duzznt start...
Yes, and run until the voltage in the battery gets drained(since the alt. not charging) too low to support ignition.hmmmm so IF the alternator is blown the car would still start??
