I drained the brake fluid in my reservoir the other day with a turkey baster and filled it with Honda DOT3 fluid and immediately afterward, my ABS light came on.
It won't go away after trying to reset it and after tripping the service connector light, it won't tell me what's wrong, either. Help!
Here's what I tried (Updated):
* Jumpered Service connector - ABS light stays solidly on (no blinking)
* Tried resetting ABS via pulling ALB2 fuse, disconnect battery, etc. = doesn't go away
* Tested motor operation by jumpering connections in fuse box per Helms manual. Motor works.
* Tested ABS motor relay with external battery. Works as expected.
* Drove the car up to 60MPH and brakes HARD. ABS does not engage (although my new rear pads and bedded in quite nicely).
I read the million and one threads in this forum on ABS and I haven't found anything that exactly matches my situation.
ABS Testing:
Q: Could air have gotten into the high pressure part of ABS system when I drained the Normal Brake fluid reservoir (in front of the driver) and would this air cause the ABS light to go on but NOT report any codes from the ABS ECU?
Possible Root Causes (near as I can tell)
* Air in ABS system?
* ABS ECU
* Blown underhood fuses [eliminated]
* Bad Motor Relay [eliminated]
* Bad Backup Relay [eliminated]
* Bad wiring
* Bad Motor (Suggested by friendly service advisor. Quoted $1200 to fix) [eliminated]
* Motor could have relief valve stuck open
* Pressure Switch
* Solenoid
* Power to ECU
From my standpoint, anything after the first item make it not worth fixing on this commuter car - I'll just disconnect the ABS brain behind the seat and forget about it. I've driven cars w/o ABS before so it doesn't bother me that this car wouldn't have it anymore either.
For the sake of completeness, here are the other things I've done in the past week which might have also "triggered" the ABS light.
* Installed a keyless entry system. All taps were into the ignition switch harness and the harness going into the security brain.
* Installed a K&N filter
* Replaced my rear brake pads LAST WEEK and used a sparse amount of squeak stop blue goo.
Any thoughts?
-g
ABS Testing:
* ABS ECU
* Bad wiring
* Pressure Switch
* Solenoid
* Power to ECU
Any thoughts?
-g
