Hi,
I recently purchased a 91 Acura Legend! YEH!
Drove fine for the past 2 days, but today it decided to die on me.
The car will start fine for about 10 seconds, then the engine light will come on and the car will end up dying (shuts off). I dont need to hold the key in starting position so its not the ignition, and the engine light doesnt come on until AFTER 10 seconds (ish). I can also drive normally in these 10 seconds, before the light comes on and shuts off my motor.
I was searching on forums, and it points to a main relay and fuel pump possibly. Is there anyway to check if its a main relay or fuel pump without replacing it?
The temperature has never risen past operating temp (1/2 or so), and ive always had heat... So I dont think the HG is toast. However, there is a bit of white smoke when I first start / drive the car.
One thing to take in mind though, I was low on tranny fluid when I checked it today, and filled it up after but the problem still didnt go away! BTW: this is an Automatic.
Any suggestions? I have it at a shop right now, hopefully they can find out the problem... but I just want peace of mind, plz any response will be good!
