HELP! COOLANT PROBLEM!
911 views 7 replies 4 participants last post by  DrOlds
so i go to the dealership today to get a coolant flush the coolant in my car was green since i got it at 120kms its at 150kms now so i said to my self time for a coolant flush so anyway they do the coolant flush i take my car home i waited about 2 hrs til the radiator cap was cooled down i opened it and what do i see GREEN coolant!! MIXED WITH LIGHT BLUE COOLANT !! so now it looks like a DARK BLUE COOLANT kinda looks purple WHAT DO I DO !! is it ok to mix coolant like this i dont think they flushed my coolant properly i think some of the green coolant was left behinde and its mixing with the blue coolant they put in this is BS!!! :mad: :mad: :mad:
#6 · (Edited)
Your car can be fuxxed up by adding some whacked out coolant such as **Dextron/GM coolant** I ended up needing a new engine but the Lenend contined to run even while crippled with a BHG for 4,000 miles!
anyway, as long as you get all the dextron "mean green" solution flushed out, no prob. honda coolant 4ever . . ..
#7 ·
went back to the dealer those cocksuckers told me they cant do anything about it because there was some green coolant left in the engine block and theres no way they could get that coolant out so the only thing i can do is keep flushing the coolant til the green coolant is completely out of the system
#8 ·
Correct. There is a block drain plug, but at a minimum you will have to remove the driver side axle to get it out. The total capacity it around 2 gallons. If you have half good, half bad, just flush it 3 more times- 3 pre mix gallons. Will take it to 25/75, .125/.875 and then 1/16 to 15/16 ratio bad to good. 1/16 of 2 gallons is about 1 pint of bad coolant in there. Pretty negligible amount.
