Unless you've got a real bad problem with your tranny, you shouldn't need to do the f-type fluid thing. If you do, only leave it in for a short time - a trip around the block for instance. As long as you use Honda fluid, you also shouldn't need the Smart blend additive. I found some on the net a while ago, o a yahoo search and you'll find it.
