The other day, as I was driving, my car just stopped. I pushed it over to the side of the road and started to diagnose the problem. It turns out that the engine wasn't getting any gas. I then checked the fuel pump fuse and it was burnt. I changed the fuse and the car started up and I was able to get it home. Now this morning I try to drive the car and the fuse burns out again. I changed the fuse four more times after that and they all burnt out after I had driven the car a few feet. Prior to this problem, every time I hit a bump in the road, my horn would go off, my right turning signal would light up on the dash and my left HID bulb would flicker (all this shit when I hit a bump but not all the time). Now I have the fuel pump issue to add to the list.
Now, all of these problems started after I changed my wheels and tires from 16" wheels / 205/55/16 to 17" wheels / 225/45/17. For some reason after I made the change my Konis and Eibach suspension became a little more bouncy on bumps and it's like the suspension has more room to travel up and down. I think my problem is that with the extra suspension bounce and travel, something is hitting up or rubbing against some wires.
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comhttp://www.acura-legend.com/vbulletin/ /><o:p></o:p>
</o:p>
[FONT=Times New Roman][SIZE=3]I found a group of wires in the front of the car, to the right of the overflow tank. If you pull up the tank you can see a group of wires rapped up together. Can any one tell me what these are for? Mine look a little beat-up.[/SIZE][/FONT]
<o:p></o:p>
<o:p></o:p>
<o:p></o:p>
[FONT=Times New Roman][SIZE=3]Thanks[/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3]Rob[/SIZE][/FONT]
</o:p>
<o:p></o:p>
<o:p></o:p>
<o:p></o:p>
