Help Help Help Overheating Legend Ky
Ok guys I could really use anyones help with this overheating prob in my 92 Legend first off its not bhg I just had those replaced 4 days ago, and car ran fine until last night when it started overheating. Ok driving home noticed that it seems like the water pump was only working part of the time temp gauge would go up so i turned on the heat to see if water was pumping thru the heater core and noticed it would get hot the gauge would go down but when the air got cool gauge would start going up but if i reved the engine hard it would get hot again. But then it just quitting getting hot all together could the pump be bad or something in there clogging it up also for some reason the fans aren't kicking on this on top of the other prob i know one of the wires somehow got cut cause somehow the harness came looose and touched the belts but when i put them together to see if the was the prob it still wouldn't come on at all I just sunk way to much money into this alrealy new head head gasket hoses and all that and it hadn't overheated at all since i had that done till now and i had drove it around for a while with no problems till now I need to get it fixed but don't want to sink money into the wrong prob any help would be apprcietated and anyone near ky that want to help work on it that be coool too lol
