1 - 2 of 2 Posts
I've managed to completely take everything loose for my timing belt job but i can't get the socket off of the bottom crank pulley. in the manual it says to use a chainwrench to keep the pulley from spinning. i've purchased two so far and none of them are long enough to wrap around the pulley. I have a 91 Legend. Any suggestions or address to where i can buy a chainwrench long enough to hold the bottom pulley in place while i unbolt the bolt. Or even better, where i can purchase the tool that the manufacturer uses. Acura parts says they can't sell me one. And i refuse to stick a screwdriver throught the crank pulley ( don't want to mess up the oil pan).
Please. i really need to do this before spring break is over!:( :confused:
as a last resort try putting a socket and breaker bar on the crank bolt turn all the way to the right till the breaker bar is touching the frame rail spin engine over with the key just a little and it will come loose i promise you.!!!!!
1 - 2 of 2 Posts
