I tried almost 2 hours today, can not find a way to take it out from the car.
Somebody mentioned, don't need to unbolt it, just slip it out. Can somebody here explain it a little bit?
Thanks very much.
Welcome to the forums. Where in Canada re you located exactly?
The relay should just pull right out with enough force. I can't remember exactly where it was located but usually, those cube relays just unplug like the rest of them.
It's behind the Lower Dash panel/cover below the steering wheel. The cover is held by 3 10mm bolts; one behind the courtesy light switch and 2 at the bottom of the panel. The instructions for panel removal are in the DIY section (I think). Once the panel is removed, the module is on the left side, beside the main relay (if I recall correctly). Once you have the module out, you can refer to the repair instructions at the below link:
Honda Accord DRL Relay Repair HOWTO
