Someone correct me if i'm wrong...............
U wanna to take off the black plastic lip around the shifting gear. It has four teeth to pull up. Do it gently not to break any teeth. Than u wanna go ahead and pull the wood dash trim by pulling it off (gently again). They hav metal teeth that are snaped to the frame. And ur there, there's the stereo, go ahead and take off all the screws and pull it out. Someone reply if i left something out.......Good luck & tell us how it went!.
Latin.......................
has left the building
You are right, sir with the exception of removing the 2 phillips head screws that are in the coin tray under the ashtray.:D
Good call! I forgot about those :D ;)
