Q: HELP Requested with Keyless Entry Installed (DEI Valet 712T)
All,
I have a problem. The next time I'll just pay the damn $50 to get the an keyless entry system interfaced to my factory alarm in my 92 Acura Legend L Sedan vs. putting it in myself.
Four hours after starting this project with a friend, my keyless entry system still doesn't work *and* my factory alarm doesn't appear to arm when you lock the door. Having gone this far though, I'm not eager to throw in the towel just yet - that's why I'm asking for help here.
CURRENT SETUP:
I have the keyless entry brain tapped into the following wires:
* 12V Constant (hooked into the ignition switch harness - easily accessible where it plugs in near the kick panel)
* 12V Accessory (hooked into the ignition switch harness): likely tells it to shut down when the car is ON
* Passenger's Door LOCK signal: Green/White on connector that plugs into the sercurity alarm higher in the dash.
* Passenger's Door UNLOCK signal: Green/Blue on connector that plugs into the sercurity alarm higher in the dash.
Gunn's Analysis: I believe this car taps into the passenger lock vs. the driver's lock b/c the way the Legend is wired unlocking the passenger's door with a key unlocks ALL the doors while unlocking the driver's door only unlocks the driver's door. I got the wiring colors from the Bulldog security website.
* Grounds
* Dome Supervision Light
* Parking Light Trigger
* Programming Switch
* Programming LED
CURRENT SITUATION
With the Keyless Entry Brain Plugged-In:
* The LED is active when the car is locked and turns off when you turn the ignition ON.
* The programming switch works
* When you press a button on the remotes, the dome lights and the parking lights blink.
* PROBLEM: when you try to lock or unlock the doors, the keyless entry system doesn't work.
* PROBLEM: When the door is locked with the switch or the key, the security system does NOT ARM. This is true even if you pull the keyless entry brain off the car and just leave the harness "tapped" into the wires.
Gunn's Analysis:
I believe this means the keyless entry brain works and is connected to the following wires: 12V constant, 12V Accessory, the Dome light wire, and parking light wire.
Q: Am I tapping into the right wire to lock/unlock the doors?
I double checked and have measured continuity from the Keyless entry harness to the harness going into the security brain so I know that if I picked the correct wires for the LOCK/UNLOCK, the damn thing should work.
Is there another situation that is causing this headache (perhaps a blown fuse)? If so, where should I look to remedy this problem? What else should I check. The car appears to lock normally (doors all lock when you lock turn the key in the door) but the security system doesn't ARM itself anymore.
Please advise!
Regards,
-g
All,
CURRENT SETUP:
* Grounds
* Programming LED
CURRENT SITUATION
Gunn's Analysis:
Please advise!
Regards,
-g
