I know this a simple task but I need some input before I perform surgery. I was putting tint on my windshield & unattached the rear view mirror from what ever was holding it in place. It
did not come out completely but its just dangling. How do I take off the whole piece without damaging my courtesy lights ?
Pry off the lens of the lights. Then, you will see two (?) screws. Remove these, and the the whole map light assembly will be removable. Did you remove the three screws that hold the mounting plate to the roof panel? If you didn't, and it's just dangling, you probably ripped it through the metal mounting plate. It's an easy fix, though.
you sould just take off your rearview all together and replace with a camera hooked up to monitor...chicks like this shi t, plus it looks cool when you leave someone in the dust.
