1 - 2 of 2 Posts
All of a sudden my car started making this whistling sound. I rolled down the window and it sounds like i am draging a chain behind me. It sounds as though it it s\coming from the rear of the car. When i use the brakes the sound becomes more high pitched. And the sound olny occours above 20mph. Have any of you experinced this. I figured I'd try for help from you guys before the dealership. Thanks, Cody. '87 sedan auto
Pull your rear wheels and check your pads' thickness. Sounds like the brake pad wear indicator is squealing (as it should) to warn you that the pads are wearing down. If this is the case, not immediate urgency but you should plan on replacing in the next several thousand miles.
1 - 2 of 2 Posts
