60_cent said:
I'm hoping to install them my self although I never did one on a Legend before. However I have replaced a pair in my 00 Civic Si I used to own. I thinking it should be about the same. The only thing I hate is if the axle is hard to come off. My weaksauce walmart impact gun always has a hard time with it.
Also did you go with the reman of the brand new unit. Even though I'm planning on installing them myself I don't plan on doing it again no time soon, never again if possible.
The left and right drive axles are different. The left side axle has a different configuration of the end that goes into the differential. You will note that the left has a female end, splined inner, that goes into the differential and also a male end that slides into the seal installed in the differential case,all in one. The male end that slides into the seal should be silky smooth and shiney. I had to reject three axle, two from Napa and one from Autozone, because the male end, supposed to be smooth and shiney, was sandblasted during the reman operation and the supposed to be silky smooth seal contact area was rough and course. Had I installed the axle as purchased from NAPA/Autozone the diff. seal would not have lasted very long. The sales people were not knowledgable at all about this until I pointed out the discrepancy.
By the way you can purchase the boots,inner and outer, and R & R your axles if the bearings/rollers are still good. Hell of a lot of savings doing the job yourself and it's really not difficult. The Helms has all the info you need to do the job.
Good luck. RAP
