SO BASICALLY, we could just get the H4 HID kit for our JDM one-piece headlights? If so, then I just found the answer I've been looking for for the past month!
I heard something has to be altered for a perfect fit.
read my previous post. yes, our jdms use h4h as the low/high beam (similiar to honda civics), but alteration of the h4 bulb makes it possible for the h4 bulb to fit into the h4h slot.
ATTENTION: I JUST FOUND OUT THAT IT'S POSSIBLE TO FIT 9006 HID's INTO THE JDM HEADLIGHTS!
do you mean just put the H4 bulb into H4H harness with mods? how about just change the whole harness? I am going to get my JDM one piece 4 door sedan soon and I don't plan to splice the wires. Instead, I am planning to put the OEM USDM wiring harness into the JDM one piece. have you or anyone else try this before except ChrisK?
I think it's not all that hard just by looking at it.
I would of did the modification if it wasn't for me doing a whole retrofit with
Audi A6's projectors in my 1-piece, similar to Matt's with his BMW X5 lights.
I know Dv8, has done it with the 9006 HID bulbs in the sedan 1-piece.
The question is, HOW ARE YOU SUPPOSED TO HIGH BEAM with 9006 bulbs? The H4/H4H bulbs have both low/high beam capability in itself. Help someone!!! A solid answer on what HID kit to buy for the JDM headlights would make my life complete!
Darith brought up a good point, how will the high beam work, since the wiring for our assemblies splits the low/high beams wires? if the JDM was put in, that means u really couldn't have a high beam right? it would be the yellow light that lights up right?
so u think it's hard to put the low beam and high beam at the same place in the JDM one piece where the OEM USDM headlight are?
if someone modify the slot somehow to fit the H4 bulb into the H4H slot, then for the high beam, can't you just put it at where the JDM fog are with some modification? or you have to sacriface and not having the high beam if you route to modify the H4H to fit H4?
Actually, when Eric Y had his 95 Coupe with 1 piece, he had the H4H wired to the hgih and low beam and used a US version foglight switch to turn on the inside goflights. It was the best of both worlds. As far as I know, H4H, is still simply a 3 prong bulb with a common ground. You simply need to wire the common ground to the low beam ground, and wire the low beam positive to the low beam prong, and the high bean positive to the high beam prong. I believe the low beam wire on the US verion harness in green, and the high beam wire is red, while both use black for ground. But with HID lights, you simply loose the high beam, unless you fake it by wiring the hgih beam to the JDM foglights.
but i don't have the fog light on my legend. so how hard is the wiring to get the JDM one piece fog light to work?
do you think it's possible to get the fog light works without the switch? what i mean is this. everytime you turn on the headlight, the fog light automatically turn on by itself. this way you don't need a swicth for the fog. is this possible?
it really wouldn't be any harder than wiring some aftermarket fog lights in your bumper.....
IF I was doing it I could tell you what to do, but then again I CAN tell you what do to make it happen.
Just follow the instructions for installing fogs (hell, they even sell remote control setups for fog lites for like 50 smackaroos....no wiring or worrying about where to put the switch, etc in your car)
in the tutorial, it takes the current from the corner light and use the relay to pass it through the bumper light so the bumper light will have the same effect with the corner light. my plan is by taking the current from the low beam of the headlight and use the relay to pass it through the fog so that my fog will on whenever the low beam is on.
do u think it can be done?
how about the fuse? do i have the same rate or larger rate amps for the fuse? thanks
