I was doing about 65mph and the engine just stalled. My G1 has 260K+ miles but I have never had a problem with the drivetrain. I pulled over to the side. Car started just fine a moment later and haven't had this problem yet. Any idea what could have caused the stall?
I can't remember which, but I believe its either your fuel pump or fuel filter. I think its the fuel filter. Its way cheaper to replace a fuel filter than a fuel pump. So take a look at your fuel filter.
Check your main fuel relay. They are a known problem on G1 legends and they can do some funky things. Normally they cause intermittant starting problems, but they can check out at any time.
If it has never been replaced you should probably change it anyway, becuase the problem is coming.
