Nice wheels, but if I'm going to upgrade from the GS wheels I'll go 17's...Size: 16x6.5"
Bolt Pattern: 5x114.3mm
- not sure of the offset -
205-60-16 tires -- rear hankook radials, front goodyear eagle ls (believe they're radials too) tread left on all tires is about 70%
Most Honda wheels will need to be bored out, especially from newer Honda/Acura cars. The only wheels that did NOT need to be bored out that I found were the NSX fronts.Do you guys know 1999-2001 Honda Odyssey wheel bore size?
I am trying to get a list of wheels which fits like the OEM wheels?
especially without having to bore out the wheels to 70.2 mm size.
The wider rear wheels will not cause problems. I'm using the NSX rears (8.5in wide) as my fronts and they are fine. Honda/Acura wheels in general have very positive offset (wheel is sunk "in" towards the car's centerline) so many wider wheels will be alright. NSX rears fit well in Legend wheel wells so I don't see a reason why S2000 wheels wouldn't. Just bore and mount.dumplin101 said:s2000 wheels will fit if im not mistaking. the back have a bigger width size though, so try to get two front. and the nsx front will also fit. i dont know of anymore. im looking for s2000 myself.
