I have a Kappa component set that i want to put in my front door. It's the 60cs series, but i can't get it to fit the black housing that the old bose speaker sit in. Is there anyway that i can get this speaker to fit into the housing? Thanks!
cut it out
Just cut out the back of the black housing. I used a rotozip on mine or if you did it right I suppose you could use a jigsaw. I've had no problems with mine and I'm running the Infinity Perfect 6.1's that are a tad bit deeper than the 60cs.
