how can you tell if your water pump is bad?
1326 Views 2 Replies 3 Participants Last post by  BIGBOY
i dont see any leaks but what would not function right?
The coolant would not circulate threw the system right if it bad. I had one of blades break off it and it didn't move coolant properly in the system. I had no leaks of any kind. It just froze up one day
Some if the signs are: weaping from the pump, if you remove the radiator cap while the car is running the coolant won't be moving. While driving the temp will be normal, when setting still temp will rise.
