1 - 2 of 2 Posts
I've managed to completely take everything loose for my timing belt job but i can't get the socket off of the bottom crank pulley. in the manual it says to use a chainwrench to keep the pulley from spinning. i've purchased two so far and none of them are long enough to wrap around the pulley. I have a 91 Legend. Any suggestions or address to where i can buy a chainwrench long enough to hold the bottom pulley in place while i unbolt the bolt. Or even better, where i can purchase the tool that the manufacturer uses. Acura parts says they can't sell me one. And i refuse to stick a screwdriver throught the crank pulley ( don't want to mess up the oil pan).
Please. i really need to do this before spring break is over!:( :confused:
Are the two chains on the chain tools the same size? If not, you could buy two of the same tool and a chain seperator tool and make the chain longer yourself. You might be able to do it with a nail set or something as well.
1 - 2 of 2 Posts
