How do I treat this condition? Paint haze
3.1K views 14 replies 8 participants last post by  Dizzydude
Last couple of times I washed my Legend I noticed a couple of patches of haze on the hood. If you look at it at an angle it shines pretty nicely but if you look at a reflection of something you can really see it.
I pulled out the porter cable yesterday and went over the entire hood
3m Swirl Remover - Dark Colors (Orange Medium Cutting Pad)
Meguiars Scratch X (White polishing pad)
3m Liquid Wax - red waxing pad
very little improvement to the hazy spots but the rest of the hood looks great. Should I try a fine cut rubbing compound on those areas?
#2 ·
Sounds like just some corrosion, but could be damaged clearcoat. If it's the clearcoat, then there is nothing that can be done. I had some luck with my Meguiar's Dual Action polisher and #M-80. Do a small area at a time slowly with about 15 lbs of pressure. I made the mistake of spreading the M80 as it became more liquid causing it to dry out. You need to make sure it's still wet when you wipe it off.
#5 ·
If it is the clear coat I dont think you will be able to do anything about it.
#6 ·
Doh, thats what I was fearing. We'll I'll give it one more shot with a fine cut rubbing compound this weekend and call it a day.
#8 ·
I had this hazing on my `95 KA7, on the roof, part of the trunk, & a little bit of one of the 14/ panels. It is the clear-coat defecting, and not much can be done about it. I actually wrote to Acura a few years ago when we lived in Central FL., as I had found that most black & dark green Legends had this problem. Acura wrote back that my warranty was up, and to 'Have a Nice Day.
End of story; went to the Acura Dealer on Orange Blossom Trail in Orlando, they confirmed that it was a paint/clear-coat defect, and charged me $700.00 to strip & repaint the problem areas. Outcome; Nice repair, perfect blend into old finish, and the car is just fine 5 years later. Acura in Orlando stressed not to use an aggressive compund to try to get rid of this hazing ourselves, as it could cause the clear-coat to start flaking off!
#9 ·
I managed to remove that hazy effect, I just used some 3m Fine Cut Rubbing compound and an Orange Medium Cut Pad.
Thanks for everyones suggestion
#11 ·
I like 3M products but they tend to dust very badly and cake up your pads quickly too. I used a small dab of the rubbing compound and after 2 minutes of buffing one 2'x2' area it was throwing dust all over the place.
#13 ·
I don't know if I was dreaming or what but I had some haze on my roof and after going over it with a claybar and quick detailer spray it seems to have disappeared. But since you've gotten rid of it maybe you might want to keep this in mind?
#14 ·
I tried the claybar first, I thought maybe it was a bad wax job. It felt good but still looked pretty bad. I thought I'd have to get the hood resprayed.
