Location
Coupes have their ECU's under the carpet on the passenger side footwell. Mine Legend Coupe has this located under the carpet where the passenger rests his feets. So, if you can´t find computer under passenger seat, pull up carpet near foot area and look there. Then pull back the top edge of the carpet and you'll see a little plastic window. The "blinks" LED´s will be found there. The ECU should be located under the passenger seat. I suggest, getting a manual for your car as some cheap insurance. For the ECU, make sure you ground yourself against metal before touching the computer. Static electricity kills computer components !! It is just a couple of screws and 3 plugs. Not more.
RESETTING
Either:
- You need to pull out the alternator sense fuse located in the engine compartment. It should be a 10 amp fuse (red). Pull it for more than a minute and that should do the trick. It should clear the ECU codes.
Or:
- you can pull the connectors off the ECU.
Mike / Cologne
