I've got it circled in RED/arrows for you... unit is fastened with two rivets <= they must be drilled out; only then you can make your adjustment... and NO jumping on any of the plug is required.Can you please show/describe to me where the ignition timing adjustment screw is?
1.Anywhere here?
2.Do any plugs need to be jumped in order to read the timing?
Thanks!!
There it is. After I drilled the rivets to remove the cover, I drilled a hole in the cover and reassembled it. The hole in the cover is for screwdriver access for next time.I've got it circled in RED/arrows for you... unit is fastened with two rivets <= they must be drilled out; only then you can make your adjustment... and NO jumping on any of the plug is required.
^^^ Very clever my friend :thumbsup: ...and yep I'd agree, not a whole lot in terms of adjustment. But, if you can keep all of the emission components in good working order by performing necessary interval maintenance, the ECU will pretty much compensate deviated signalsAfter I drilled the rivets to remove the cover, I drilled a hole in the cover. The hole in the cover is for screwdriver access for next time.
Big deal....there isn't much adjustment anyway. +/- 3 degrees, IIRC.
Timing light would (and should) verify all changes made regarding timing... and, the adjustment screw (at least to my understanding) is for redundancy purposes. Any out of telerance signal(s) detected by the ECU will trigger it to go into "limp mode" thus affecting efficiency.Is there a way to tell if the ecu compensated for the timing screw change?
Why would Acura waste $5 to put in a timing adjustment screw if the ecu makes all the adjustments?
My guess is that the timing isn't spot on when the car is assembled due to assembly tolerances, etc. The timing adjustment pot is there to dial it in on the assembly line once the engine is installed and running.Is there a way to tell if the ecu compensated for the timing screw change?
^^^ True that... just keep them emission components functioning properly :yes:The cover is riveted to the pot. This almost "permanent" sealing or anti-tampering device put over the pot tells me that it's not made to be messed with on a regular basis.
