Firstly, it says that to check the level of the oil, you have to be on level ground. Problem is, once you jack it up, it's no longer level.
Secondly, how do you fill the oil?
The only way I can figure it is to have it on a lift. Or possibly backing it up into my driveway which has an incline, and then jacking the front up; but I don't know if I'll be able to jack it up high enough to get it level. Anyone been successful at figuring something else?
