I do my best to help you. I replaced my bulbs before some months. So I will upload some pics of my work so that you can see, how easy it is. Don't worry, be relaxed by doing this. It's really not difficult. I will try to give you a good detailed "How To..." preview, so I will give you only the pics of your A/C Vent. I hope that you will agree. I hope also that you already know how to remove the stock radio. If you want, I will give you the pics too. Regarding of the replacing bulbs, be forewarned: These damned bulbs are not cheap !!!
Ok, no prob. Here we go....
Radio Removing
1st: Remove your wood cover of the center console.
It's very very simple! If you have an ATM (Automatic Transmission), you must (flat screw driver) pull out the small black cover, then remove the 2 screws under the ash tray and finally pull gently the whole wood panel. Be careful: ONLY PULL this panel! Be careful when you remove the trim, it is somewhat fragile and cracks fairly easy.This panel contains 6 clip holder (2x upper, 2x in the center and 2x lower) )
2nd:
After this, unscrew the 2 screws. The radio (stock radio) is held with 2 screws. At the next step, you can finally pull out the radio, After this, you must pull out the...
- snap-in wiring plug
- antenna cable
- 7-pin DIN cable (CD changer)
- 5-pin of Audio control
JUST MAKE SURE THAT YOU HAVE YOUR RADIO CODES BEFORE YOU DO THIS. OF COURSE, ONLY IF YOU HAVE A STOCK RADIO. Now be careful - you will lose the memory settings when you disconnect the battery. So you will have to re-program the settings.
3rd:
Air Vent Unit
These unit contains 2 screws under these unit. Reachable only it, through the opening radio tunnel. These screws are in the top of left and right side and not difficult to find. Remove the screws and try to pull out the whole unit. These unit contains 2 metal clips (in top of the unit, left & right). After this, you should remove the 4 cable connectors. Notice your unit in the center of the pic.
1. The complete assembly.
2. Here the available cables. Please ignore the "Fog Plug". US Legends don't have it.
3. Here the whole unit. Notice the two screws. You must unscrew these to get the whole unit out !!!
4. Here you can see the rear side of the whole unit.
5. Notice the metal clips. Very important, when you pull out them !!!
6. Now you can start to remove the several parts
7. Here you can see the removed cluster trim.
8. Here the "Main Control Unit".
9. Turn the unit. Do you see the back of the white bulbs?
10. Here the rear side of the "Main Control Unit". Do you see the small screws? You must unscrew these.
11. The Unscrewed Unit
12. Then you will get access to the inner side. Take care with the 2pin cable. The soldered points are very thin.
13. Inner LCD Circuit Panel
Don't ask me what function the switch have on the LCD circuit. I don't know it. What is written, is "[-2] [0] [+2]". I have really no clue why and whatfor it is
14. The Replaced Bulbs on the right side !
Ok, take a screw driver to turn the bulbs and take these out. After you replaced these through new bulbs, please ...
- replace all bulbs !!! It's better for the future when the same happens again.
- after you have taken out the unit, please clean the fan. Very important, because the fan make some noises when he got dirty. No you can reinstall this in reverse sequence !!! Hope that I could help you a bit. I hope I did not forget anything here. Later you will see that it's very easy. Good luck. -Mike
