I need to replace a few burnt lights on my instrument cluster (in between the tach and speedometer are the PRND3D2D1 lights for the automatic transmission).
How the heck do you take it out??
On my older 1988 Legend Coupe, you removed the cluster straight out the front above the steering wheel.
This 1992 Coupe has me puzzled. I removed the decorative cover underneath the steering column and looked around, and it confused me, so I did not go any further.
ANYONE HELP??
Hey, it is actually pretty easy, but for a visual aid go to
www.legend.ca
then go to the "DIY" at the buttom left hand of the page.
then got to the last choice out of the 4.
Just flow that and you will be fine. Just make sure to remove the light switch and then remove the screw that holds the bracket in place and the rest just fall's apart.
Good Luck.
