if you are pulling it out with the tranny and diff, you can pull it with the whole front clip, ie sub frame, wheels, suspension, axels and all, all you need to do is unbolt from frame/body and wireharness, vacuum lines and such and just lift the body off, and if you are not reusing the old body you might even be able to torch some of the front clip offand pull out in a few hours and then disassemble off body, i would make the drive for a major project like this, you would need all the help you can get...
