my VSS has been out for a while and i know if i order one from AH Motorsport it's only like 80 bucks or something as opposed to like 200 at a dealer. my question is, when i get the VSS how much would it run to take it to a local mechanic to have it installed? i'm assuming and hoping not as much as at a dealer. anyone have experience with this? thanx!
It took my amateur mechanic ass 1.5 hours to do-
Vehicle Speed Sensor
oil change
manual tire rotation
The VSS took me 45 minutes, and that was not knowing what the hell to do either.... acura wanted 1.5 hours labour from me... scam artists...:rolleyes:
If i were in your position I would replace it myself Just raise the front of the car on jack stands,locate the vss and replace, if I remember correctly all you need to do is disconect the electrical conector form the vss and remove the one bolt holding it in place also discomect the hose connected to it and plug it untill the new on is in place.
