how to remove front bumper
1921 Views 1 Reply 2 Participants Last post by  MikeD
mine is falling off slightly, there's a gap between it and the rest of the car. anybody know how to remove it off of a 94' Sedan (94-95 have different grilles than 91-93)...thanks
1 - 2 of 2 Posts
To remove your bumper...
1. Written by luvmylegend (moderator supreme!)
about 10 on the bottom, and some other one's I really can't remember where they are. plus there should be four 12mm bolts that you'll have to remove the bumper lights to get to. to remove the bumper lights, you'll have to take the fog light covers off at the bottom front of the bumper, and look up and there will be a phillips head screw you'll have to loosen to get the bumper lights out.
2. Written by ChrisK
It is easy. You need to remove a total of 14 screws and bolts. You need to remove the phillips screws holding the foglight cover in place. One on each cover (total two). Then you remove the bumper turn signal by loosening the two phillips screws holding it it in. One for each light (two total, running total of 4). Then you remove the 4 10mm bolts from the under side plastic shield. Two on each side (total 4, running total 8). Then you unscrew the two plastic screws toward the center part of that plastic shield. Two total, running total 10). Now, you remove the 4 12mm bolts holding the bumper in place. These are accessed through the hole left from the bumper turn signal. (4 total, running total 12) For the Coupe, there is only 2 12mm bolts holding up the bumper, so the total would be 12 bolts.
Now, if you are going to paint, you now have to remove all those plastic screws that hold the bumper cover onto the bumper itself.
After you get used to removing the front bumper, you can pretty much do it in 5 minutes.
1 - 2 of 2 Posts
