Well, I got it done. I removed all the OEM intake parts, removed and cleaned the throttle body, installed the ram intake, and bled the cooling system all in 3 hours. I did run into a few obsticales. First I noticed that I could not remove the rubber part of the intake between the battery and headlight. It seemed to be glued in right over a screen. I got out my dremel and cut it in half, then I took my metal snips and cut it all out piece by piece. Is there another way to remove that? Everything went smoth for a while again until I installed the filter. It was wedged up against the hood sensor. I removed that and had some room to play with. I also think doing this disabled the OEM alarm. I know it would on a G2. Some more smotheness and then I got to the vacume line. I only found one vcacume line on the OEM intake. When I compared that one with the one that came with my intake the new one was much smaller. I bypassed all the OEM vacume line and just ran the new line straight to the port on the rear valve cover. It was very hard to get that on, but I managed much to my own amazement. Anyway...it got smoth again until I put the batery back in. The filter is wedged up against the batery and the mount the hood switch was on. It almost seems like the tube is to long and not bent to a sharp enough angle. I wonder if switching to the K&N filter will resolve this. I can always take it to a muffler shop and have some length cut off. I have decided to move the battery to the trunk as my next project. This will help with weight distribution and let me play with something else. My muffler shop is going to look into making a CAI extension from the ram intake. I don't want it winding around the battery, so with it gone I have a much more direct route. Let me know what you think!
Later!
Lee
Later!
Lee
