What's the best way to tell which wheel speed sensor is bad my ABS light is on in my 1992 Acura Legend LL and as you all know ABS is very helpful in the winter I hope to hear from you and thanks in advanced for all your help
you might just need to top off your brake fluid resevoir driverside top of the engine bay and the ABS resevoir passenger side. both with DOT3 brake fluid. my abs light came on after a few seconds when i ran the car, then i topped off those resevoirs and the lights didn't come on again yet. and its been like 4 days since i topped em off!
good place to start for an easy $1 fix. hope that helps!
you know about the plug that you put a jumper on and then your abs light will blink...well count the blinks and check a chilton manual and it tells you which sensor is bad....if you dont know what im talking about just go buy the manual and it explains it it there.
