The lights on my shifter went out (the lights that tell you what gear you're in). Checked to see if it was a fuse or a bulb, but couldn't find anything. Any ideas.
If you are talking about the shifter between the seats, then yes, there is a single light bulb. You remove teh black trum around the shifter, and if your had is small enough, you can rach the bulb on the drivers side of the shifter. It just twists out. If not, you have to remove the wood trim to free up more room.
I had the same issue, and Chris K is correct. I took a buisness card a pried the little plastic piece upward. I used a buisness card, so I wouldnt scrath the wood. Lucky for me the bulb was loose. Pushed it back in and, booya.
