1 - 2 of 2 Posts
I have to run some wires for my CD changer from the trunk to the passenger compartment, and couldn't find any access holes. Also, my seat does not fold forward and I was unable to remove the seat bottom to see any holes. Any ideas on this? Thanks in advance.
I have a '90 LS coupe and I had to take out the back seat to do this. There are 3 bolts between the seat and the back where the seat belts go. Unsrew these three and then pull the back end up and back. (It also has 3 clips on it- just push it back to release it.) You should be able to slip the wire into the trunk from here. Slip it under the back of the seat. You also have to take off one of the plastic things that join the carpet and the body at the door. There are 3 philips screws and then just take it off. Pull up the carpet a lil bit and slip the wire right in.
Basically you can slip wires easily into most parts of this car. Just push it under the plastic trim and most of the time it will go. Any other questions let me know.
1 - 2 of 2 Posts
