1 - 20 of 21 Posts
mackmanron
· mackman
Discussion starter · #1 · (Edited)
I need help please my 95 4dr legend gs is stranded in a mall for about an hour now.
when i try to start it up it stalls right out i change the main fuel pump relay two times what else could it be, i try to give it gas to force it to stay started it will shut off.
help a brother out in need thanks
did u change your main relay
when i try to start it up it cracks up then stalls right out i change the main fuel pump relay two times what else could it be, i try to give it gas to force it to stay started it will shut off.
do you hear the gas pump turn on when u try n start it or a the starter relay click, also did you check if fuel was avalible at the fuel rails, if yea u may need to check if voltage is avalible to the coil packs, those are two of the major parts
yes i change it two times the first time it started up then when i drove a bout a mile i then turned it off then tried to start it back up it would not start
up. then i put in another main relay and it will not start up.
Discussion starter · #5 ·
dudes check this out when i put the key in the on postion there is no power no lights on the dash and no ac i change the main relay again for third time now whats going on with this car help me please
Sounds like your battery is shot...
Perhaps your alternator died and your battery has discharged because the alternator isn't delivering any charging voltage.
..Could be a faulty ignition switch..
It could be a faulty ignition switch if you get power to the car, etc when you initially put the key in the ignition, then as you turn the key the way, there are no lights. Does your horn, interior lights, and your headlights work?
Discussion starter · #10 ·
yes all of the lights work and radio and the horn there is no dash lights and it starts up then shut right back off. as if there is no gas when i try to give it gas it shuts off anyway.
Ok, try this and tell me what happens. While cranking the engine, after it starts just slowly return the key back towards the run position until the starter stops. Basically don't let the return spring bring it all the way back to run on its own. So that you will end up with the key halfway in the start position. If the car stays running then the ignition switch is bad.
The guru is 97% sure your ignition switch is faulty!
The lack of interior lights made me think other than the ignition switch but it seems they work?
In that case, almost definitely an ignition switch... good call and good to see you around Lenny!
Thanks, and who the hell are you???? Do I know you?
:giggle:
Probably not... you were around a lot (and pretty helpful too) when I first started trying to be active around here but I've seen you come and go. I was just surprised to see you drop in as I haven't seen ya around in a while.
Cheers!
-Ben
:giggle:
Cheers!
-Ben
Well I've been pretty busy with work and doing some unannounced projects with the Legend. So I have been staying on the DL. Don't wanna get flamed you know!(EDIT:) The server went down while typing this! AL.com Server FTW +1
And who was the wizeass that changed my title????? Mr. Hard to find??? Me? Never!
Discussion starter · #16 ·
ok dude i will go try this tonight thanks alot i have to go check on it anyway to make sure she is still ok i appricate your help does anyone know how much these ignition switches go for and where i can find one?
It could be the ignition switch, or the fuse under the hood. that happened to me twice. headlights and brake lights work, but no dash light, replaced the fuse that screws on (dont know if G2 has them) and my dash light went back on.
Discussion starter · #18 ·
ok i went back to the car tonight and i did what you said and you are right she will stay started as long as i hold it halfway. so now i know i need a ignition switch thanks dude anyone can help me with this type of repair and where can i find one these fast. anyone knows of a mech in the staten island area that is where i am now.
1 - 20 of 21 Posts
