Thanks first of all for letting me on here.
I have a 91 ls coupe
It is over heating and has been for over a year now. I have replaced the thermo. 3 times, new radiator, sensors, relays, water pump, timing belt, its been pressure tested 3 different times (once for two days) and it holds pressure. Fans come on as normal.
I can drive long distances with no problem, obviously at high speeds. But in town, after 20-30 min. of regular stop and go. I start to over heat. And it is over heating, there is fluid going into the over flow tank. Temp. will constantly go up them after a few seconds come back down almost to normal and progressively get worse if i continue to push it (drive without a break). I've never let it get so high that smoke starts coming from under the hood, but i'm at a loss and mechanics here are not sure whats up either. And they only work with acura's and honda's.
So if you have the heart to help a fellow acura lover out, it would be much appreciated. I have spent $1300 with no change in performance what so ever.
Thanks for your time.....Keith
